Mod: Muz X-Brace
Price: $310
Where from: Muz
Impressions/comments: One of the best mods I've done to my car! helps eliminate body roll and makes ur car feel solid through corners!! really noticable and I would recommend it!!
Rating: 5
Mod: Muz X-Brace
Price: $310
Where from: Muz
Rating: 5
Mod: Eibach Pro-Kit springs
Price: $280 used
Where from: Private sale
Impressions/comments: Installed on OEM shocks. 1" drop is nice, didn't drop immediately when installed but settled at a nice height after about a month. With 18s and tyres with a rolling diameter a teeny tiny bit larger than stock I have a one to one and a half finger gap all round. Some scrapes here and there. Feels almost like stock albeit slightly stiffer. Couldn't be happier
Rating: 4.5
Mod: BC br coilovers
Price: $1250.00 new
Where: otr motorsport clayton
Impressions/comments: very easy to install, just time consuming. very easy to adjust stiffness. easy to adjust height also, started with about 15mm drop, now at about 30mm might go even lower soon =)
at full stiffness they really change the whole feel of the car, almost no roll, alot different to get catch also. only problem is tyres cant keep up so full potential is yet to be seen.
Rating: 4/5 (not camber adjustable)
Brendan would it be 5/5 if I told you no coilovers for the s2000 come with camber tops? :P
you did? well still probably couldnt give 5/5 cause that would mean there is no better but bang for buck id says 5/5
You sure they are the same ones? Bit of a difference in price.
I assume so, that is if they are N+ racing spec dampers. This quote was bak in 08. Our exch rate 2 weeks ago approx .996
The racing spec damper are different then the ones u may have. You habe the N+ racing spec ones which are a lower spec model :D
Sockie Tech S2000 Bonnet Struts (Hood Dampers)
Price: $60inc Shipping (ebay)
Rating: 5/5 excellent quality, very easy install comes with all the parts and instructions (with good pictures as we dont like reading we are children)
http://a5.sphotos.ak.fbcdn.net/hphot..._6999936_n.jpg
