it has 215/40 at front and 235/40 rear
I should have looked at this thread! Rear is ok 17x8.5+40 245/40/17 but im having problems with the fronts 17x7.5+30 225/45/17 on stock height and camber and its poking out alittle. Would changing tyres to 215/45/17 help tuck it in alittle or should i be looking at changing to coils?
Changing coils won't help wheel fitment, 215 will sit in slightly but not that much but it will help a tiny bit because the 225 is slightly oversiezd. If your front guards are rolled that's fine, because your running such a thin front rim it's hard to stretch without going under the standard 205 tyre.
Planning on getting 17x9 +45 wheels soon and was wondering what tire sizes I should run. I was thinking 245/40 all round. But after reading a few threads I saw some guys were running staggered tires on the same wheel specs. Any benefit in doing so?
And also does anyone know where I can get some kw v3's in aus or will the states (eBay) be my only option. I've already browsed thru the traders here.
The traders Forty-One on au.s2ki.com were offering them for some ridiculously low price. Look them up.
thinking of getting cr kais..
18x8.5 +30
18x9.5 +30..
comments?
Pushing it. I'm running 18x9 +66 on the rear.
And how does that sit? I've seen 9 +38 on the rears and it still tucks
Sits fine. I can't imagine anything with a lower offset and wider width not sticking out and needing some camber not to rub.
Oh, I'm running 265/35-18 tyres too.
As of yesterday, I run a 275/35/18 on the 10" +44
http://a2.sphotos.ak.fbcdn.net/hphot..._4287877_n.jpg
Driven over any bumps recently?
