Originally Posted by
ALLMTR996
Biggest problem is guys want to be different and really they are just wasting money in the long run you need to research rules if your racing and use them to your best advantage and not spend 10's of thousands of dollars to enjoy your sport/hobby.
With a D series it takes alot to make 100kw+ at the wheels i had one that I spent hrs and hrs on the dyno with it was a full OEM build D16Y1 P29 pistons mild ported head cut open ported intake manifold 60mm TB and it would only make 99kw no matter what I did without spending alot more on the cyl head there was not alot more mid range power to find,that engine cost less than $1000 to build because I did it myself and really 99kw for under $1000 its cheap power and a hell of alot a fun to drive and did surprise a few cars and drivers on the road.Now on a race track it would not have suited with its powerband and this is why I would use a B shake in what you want to do there are a few cheap b16 conversions around PM me and I will send you the links or if you want the spec's on the D I had I am more than happy to post them up.
