17x8 +35 running on coils should be fine for fd2, am i correct?
yup all good
Couldn't find anyone putting a 16 X 6 wheels... Will that affect the handling?
16x6? what offset? That's skinnier than stock.. It won't significantly affect your handling.
16x6 is going to look funny as well lol. Go for a wider tyre if you want the car to have better handling and some decent tyres will help in that process too.
16" wheels are small, but still fine. although u should opt for something wider than 6".. i think thats nearly the same width as stock fd1 wheels. 195 tyres will look very thin in terms of stance, and wont get u much traction.. but if u compare it to stock, its nearly the same. not much of an upgrade.
stock is 6.5" wide.. so thats a downgrade..
quickly bolted these up today, before I put them back on the 180 and sold them with it :(
shame I can't keep them and shame I didn't have time to lower the ep first...
17x9 +30, 215/45 yoko s drives
http://i613.photobucket.com/albums/t...g?t=1289727442
http://i613.photobucket.com/albums/t...g?t=1289727779
http://i613.photobucket.com/albums/t...g?t=1289727787
Dam that would of looked nice if it was lowered and you had a camber kit.
Would a 17x9 +22(F) +28(R) with 215/40/17 912's all around be a problem on a FD?
Im not sure if itll clear the caliper. Perhaps with a camber kit, rolled guards itll fit. I was reading before about how even the jdm dc5r rims or something clipped the caliper. Not 100% but ill get back to you when i find more info. I want to try run 17x9 +38, so i guess if yours fits, mine will be all fine.
http://www.ozhonda.com/forum/showthr...-fit-FD1-civic
Have a read of that :)
