Hey guys wheres the DOOR SWITCH?
My passenger ones ****ed, my interior light wont turn on when the doors and open, and neither will the open doors light near my guage.
I wana take a look at it, wheres the switch/sensor? or whatever.. it is.
scratch that found it, little black thing on the chassis of the car aye?
yeh pretty much u shud be able to push it in and stuff, it usually rusts up and stops making contact mine did that, just wd40 wipe it up a bit worked nicely
yeh..mine did that a while ago...took it out..sandpapered the bit of rust out and its fine again
just did it now lol it wasnt rusted or anything the wire behind it is cut.. and i cnat seem to find the wire lol -_-
nah its in there, take the rear interior panels out and u'll find it, its just a little clip that plugs into the switch and its VERY lose, most likely it slipped and fell out.
actually if u get a wire and bend the end...stick it in to fish around..u mite be able to find the wire without tearing out the panels
A man how the hell did you get hold of that rear bumper !!!
isnt it a stock one :S ?
bumper cover ;)
Hey guys I'm having some electrical problems with my DA and could really use some help. First one is my headlights every now and then while i'm driving will glitch (dim for a second or two and then go back to normal). I've heard that it can be caused by fuse or faulty battery, so I swapped my battery to one out of my other DA, and changed the fuses but it still does it. The next problem is that my fan has stopped working on settings one and two. I replaced the inner switch but still nothing. And my last problem is that sometimes I turn the ignition to start the car and it hesitates for a second before cranking, but only really when the engines cold. The first two problems appeared within the same week, and recently, but the starting lag has been happening for a while but it's not that bad, I should probably mention that when i put in a battery with higher CCA's it started great but after a few months it slowly came back.
Any and all help would be greatly appreciated.
