any closer pics of your clutch master firewall modification? what master cylinder and pedal set are you planning to use?
did you modify the firewall or cut and shut?
Plate my climate control
Thought i would see if i could get my red crx to start.
It had been sitting for 10 years with all most no fuel, just gunna say those nut on top of the fuel filter can be a c#nt...
install valvesprings
Running s2k CMC and EK clutch pedal. There are many ways of doing it. But keep in mind that the firewall wasn't designed for a hydro clutch so reinforcement may be required either by creating flanges or reinforcing braces. I've just cut and welded. Henrygiang (maddest username) did a different cleaner approach
Bump ttt
dude we need a build thread for that beast
