Yeah
But your paying for fitament and keeping people employed :P
Yeah
Checked with the dealer, the washer for the transmission drain plug is 90471-PX4-000 18mm crusher washer
hi guys i hav changed my gear box oil with the dw atf oil as recommend in the post, but did not change the filter as the dealer said no filter required.
recently i found the magenife 3/8 filter and purchased from USA, so can i just intall the filter without changing the gear box oil ??
Edit:
Op updated
Has anyone tried this transmission filter from ebay: http://www.ebay.com/itm/321104330802...S:1123&vxp=mtr
It is not Honda OEM 25430-PLR-003. The Honda dealer sells AUD 57 per filter.
CU2 seems have a different oil filter setup
Changed the transmission fluid 3x3 on the CL9 using Penrite ATF FS - less jerking at 2nd and 3rd gear. Thanks for the advice guys!!
Most of you guys seem to have CL9's. Can someone confirm to me if it is the same issue for the Cu2's and if so what is the part number for the transmission filter? As according to "EJ25SOHC" comment above he is on the understanding that its a different setup altogether.
I flush my automatic Trans on the weekend and replaced the filter as well
I followed the Youtube video very easy, by doing this way you get 100% new fluid through the hold trans
http://www.youtube.com/watch?v=LVqiB1-DX24
Part # 25430-PLR-003 trans filter
Just to confirm the flow of ATF is towards the cabin / firewall? and I should have the arrow pointing towards the cabin?
