yeap, I called and spoke to Arthur who then got the prices from Haks. This will be the LAST mod !!..
Kpro and tune will cost another 2k.. and I really don't want to spend anymore as I've just spent abit over 2k on headers and intake...
do you guys know the difference between the 2 seibon mugen style wings?
http://seiboncarbon.com.au/products/...ic-si-jdm.html
and
http://seiboncarbon.com.au/products/...-civic-si.html
one is jdm one isnt. can anyone confirm what is the actual difference? thanks
wow, my Tegiwa exhaust is already delivered to my door. I placed the order on the 27th November and it's arrived so quickly... woot.. now the anxious wait to have it installed. I'm tempted to go to another exhaust shop, but Hak's seems to have a good rep so I'll wait.
Yeap, cars are a money pit. If I was single and didn't have a mortgage, I'd probably spend all my money on car stuff ahah
Them LV handbags to go with that baller spec ep3 man. Cars, women, money
its clear choice. hand bags hands down
because gobbies
http://www.ozhonda.com/forum/customa...ar28865_10.gif
just installed a cai on my ep3, car idles at 1100 now and when i coast to a stop at the lights it goes to 2000 and down to 1100 and back up
any ideas? checked vacuum hoses seems fine. I've plugged the temp sensor into the CAI it only goes in 1 way and it just squishes in place right?
thanks for the tip
I paranoids, so i double chcked everything, took the clamps off and re did them, took car for a drive same thing, then thrashed it a couple of time and then suddenly its idling smooth again? felt more para so went for more sprints, car is great now. Must have been the ecu learning to close loop? Not sure all is good thanks. I might clean the idle valve anyway car has a slight misfire on idle.
any recommendation for 100k service in Melb? western suburbs
Just a noob question..
What are the differences between Facelift and Pre face, is it just the light fly wheel, front and rear lights, front bumper?
What about motor wise, same power or different?
Just Researching before I purchase one, but I like the Pre face more then the facelift.. My opinion lol
under the hood is mostly same; there are very very subtle changes but its mostly exterior differences like you mentioned. you also get a bigger red H badge on the grill lol personally i have the pre FL but like the stock FL front end better, but pre FL with mugen lip/air walker is win. I never really liked the altezza look on the rear lights in the FL model.
i assume you can get FL lights on the pre FL model as well?
I see alot of headlights on eBay.. anyone tried any of them?
Aw good good, looking to buy one next year, just doing some research!
Any common problems with them?
Or if l plan to lower the car?
Nah is rather the preface over face lift.
There just some about the FL I don't like, preface is more aggressive
Be aware that a lot of those eBay ones are designed for usdm models too so if they're projectors (which is what FL should be) then the aim of the headlights will be opposite of what they should be for us.
Cheers, I'll probably steer clear of them. Sounds like they could be more hassles.
Are ep3 air cons strong? Mine doesn't get that cold when I turn it full blast in hot weather. Is this when I should regas?
So tempted to do a brembo conversion >.<
Does it matter much in terms of efficiency between a 100 cpi and a 200cpi cat? I assumed a 100cpi cat would flow better, but i've read around saying that a 100cpi cat would normally need more structural support in the build to prevent the cells from collapsing and such, and these supports restrict air flow and therefore make the gains negligible compared to a 200cpi cat. Looking at PLM headers, it comes with a 200 cpi cat, just wondering if it's worth getting a 100 cpi one.
Jdmyard have 20% off sale still on if u want to get headers from them. Yonas was pretty sneaky though, told me to come in on Friday to check out the headers and so I bought it on Friday as I wasn't aware of the sale this weekend and he didnt even tell me.. annoyed!!!
Tell me about it. Well my one had slight manufacturer fault which could be fixed so he said I could have it for 550 which is still $20 more expensive than a new non faulty one.
And these shops wonder why they lose business to traders on the Internet . . .
Nah this is 2nd hand came off a dc5r, has a 200cpi cat on it. Do i need a defouler if it has a cat?
and just looked at the jdmyard website found the headers http://www.jdmyard.com/index.php?rou...product_id=596, but no sale :S did i miss out? lol
edit: dw it's a coupon code lol
Just the bolt bracket at the bottom part of the header doesn't line up so the bracket needs to just be moved so the bolt can go through and be tightened. Nothing major.
Yonas said he can fix me up with sale price and $50 off so I'm happy with that now. Should come to about $480 for the headers from original $660 price :)
Is it worthwhile getting new engine mounts even if mine are still fine? I'm considering hasport mounts from Jdmyard since they still have their 20% off sale..thoughts?
Also, hardrace, hasport or mugen mounts?
Defs worthwhile, i'd go with hasports, im running 62a in the front and trans and 70a in the rear, vibrations aren't even bad, and become even less noticeable once they wear in. Hardrace is hardened rubber where as hasports use polyurethane; mugen apprently doesn't feel must different from stock and is also rubber.
How is the plm ground clearance? Does it make the exhaust sit alot lower? I think the last thing i want is even more scraping of my mid pipe...
Thanks. Would this be what I need?
http://www.jdmyard.com/index.php?rou...product_id=126
Haven't installed headers yet. Next Monday will be going to haks
Question: on the odo, what's trip B represent?
Link comes up with "product not found" btw, but if its the link to the dc5 or ep3 hasport mounts set then yea they're the ones. Just check with the hardness rating cause they didn't state it.
Represents whatever you want lol just reset it by holding it down.
All this talk about headers makes me want to mod my ep3 now =(
Has this been tested or do people just assume it works that way? Reason I ask is generally after filling up I will reset trip A and when I scroll through to trip B it hasn't been reset, meaning the reset should be independent, a week later when I go to fill up again I go to reset trip A again scroll through to trip B and it reads 1.5kms. So I'm like well I don't remember resetting it 1.5kms ago so what gives
you have to reset trip a and b separately. it's a trip meter. pretty simple stuff
Is a cat like this fine in place of the test pipe for the PLM headers? http://www.ebay.com.au/itm/160899862...84.m1423.l2649
I'm more unsure about the o2 bung location, is it too near the core? most bungs i've seen start where the pipes straighten out... Also did you guys get the slip joints welded?
Hi everyone!
I'm in the market to buy a EP3R facelift model. I'll be in Sydney from 26th-31st Dec for a holiday and wedding. I'll likely be taking down cash with me to buy a car.
I have been in contact with 2 dealerships with EP3R FLs in stock - Unique Motors and IMG. I hear IMG has a very good reputation amongst Sydney enthusiasts. Anyone have any dealings with Unique Motors located on Parramatta Rd, Five Dock?
Also, would anyone here happen to be trying to sell their EP3R FL?
This is from the thread I started in the Wanted to Buy section.
http://www.ozhonda.com/forum/showthr...iday-26-31-DEC)
Thanks Perry. You bought an EP3 from IMG? I spoke with Gavin today and he seemed pretty experienced with the EP3 and mentioned ozhonda.
One of the things I'm most worried about is parts availability, being an import and all. I live in Darwin and the shops up here have no clue...I test drove an FN2 and the sales lady didn't know anything about the car...
Decided to do some engine bay clean up, just wondering how do you guys clean the red rocker cover? mines got some dark dirty patches on it lol Using degreaser just made the surface turn white.
any recommendation for air con regas near cabramatta and how much?
Could go to GPC Yennora not sure if they do it anymore though.
Any recommendations for a place in Melbourne for an aircon regas?
Yo yo Mike long time no speak what's happening?
got my plm headers and tegiwa exhaust installed by Haks :) Took about 3.5 hours to do and he did a great job not that i know much but he said its sitting really well as it has good ground clearance and good clearance to the chassis. The car sounds great when you give it but when idling or cruising at less than 3,000rpm, it sounds stock so its a very very quiet exhaust. I read somewhere that its a copy of the Fujitsubo rm01a. Overall very happy. Performance wise, havent driven it enough yet as I was traveling home in peak hour.
http://img138.imageshack.us/img138/5...1210172341.jpg
Thanks to julia geebanger.
Regassing is exy as fuk.
Does anyone have experience with fitting Recaro SPG bucket seats in the EP3 using stock rails? is it just a straight fit with the Recaro side brackets?
Anyone tried them with the Nagisa SLR rails, any comments on them, is the height adjustable on these?
anyone tried lamin x on their ep3? I'm thinkin of my next cheap mod. I've done it on my Audi and it looks great..
http://img9.imageshack.us/img9/7056/20120805151306.jpg (that's the old man helping not me :))
Check this out for stock rail fitment ---> Link
