Never heard of OMNI before?? Where do you hide out?? It is def worth a try.. You will not be disappointed, i promise you..
If i remember correctly, both Flicks EG and Monty's JDM Concept/J's Racing DC5R both ran with this...
Buy a pair ship it to work other pair ship it home address or something.
Just beware of the difference they may have between their US LHD EP3 and our JDM RHD EP3.
There is a possibility that there is a difference in bolt patterns or bolt length. To be safe, I would find out if their OEM master cylinder has identical part number to our EP3. If they are same, then it possible to assume that the omni would fit ours.
Or my house, either is fine lol
i just ebay messaged the bloke selling the cmc. i'll let you know whether it will or not fit our ep's Poeter
thanks for all the responses
so its true, our rear does lift up!
http://farm7.static.flickr.com/6202/...98295534_b.jpg
IMG_2361 by
You must be going pretty quick Johno?
it felt quick, speedo said otherwise. i just went wide and threw the car in really hard
just to let you know, the guy from omni has responded. the omni clutch master cylinder fits our ep3s.
quote from omni "the firewall mounting point is the same and both master and slave cylinders match up. It's just on the other side"
hope this helps anyone out there in need of a CMC too !
Anyone on m4 this Arvo around 2.
