so type r mc bolts up fine to the brake booster and stuff?
yep, using it now, improves the feel of the pedal too, was the first mod i did when i bought the car as i drove the car home with a sinking pedal..
everytime at the lights i was pumping the brakes like pumping bicycles tyres with a foot pump...
so dc2 type r??
also do u have a part number
as honda is silly and needs a vin number
yeah dc2 type r
sorry i dont..threw out the packaging long ago...
i can look at the actually MC when i get home later if u want..
but if you ask for 2000 Honda Integra TypeR there's only one
if they want to search by VIN then its much easier...JHMDC2###############...hahahaha every other vtir/gsi are JHMDC4########
yeh man thatd be good, cuz i called em up, there like yeh like 200-400 bucks. Yeh ill get bak to ya :S
i think they are including the brake booster which is the big black thing, which will fit with modification.
http://cgi.ebay.com.au/JDM-Honda-DC2...item58875f266a
but all you need the the MC which is the front bit...
i just had a search online...u can probably get a set of that on ebay quite cheap..like whole set for 150-200..but then again..u dont need the booster
hey guys, im putting my car back together again, and im a bit stuck!
i didnt label anything =D
can someone post up engine bay pics, standard or if you have a b16a, or b18c?
thanks
jef
firewall, and aircon, condensor etc.
and just wondering if you need to use that black cylinder (filter) thats on the firewall
hey boys .. gota quick question..
i flew over a speed hump .. literally flew.
Bumper didnt hit the ground or nothing.. but something came loose? not sure what it is.. but the Right and Middle section of my bumper is VERY loose.. wobbles n shit when i move it with my hand..
all the screws and shit are on there..
Any ideas? is there something in between? When i hold the side near the wheel up tightly.. then the bumper becomes nice an tight so i thouht it was there.. i just re-did the screws there fine? its still loose as ?
can anyone help?
edit: by right i mean DRIVER SIDE
There is a bit of white plastic that connects to the chassis where that 2 screws on the side goes in, that probably came lose on the inside, undo the 2 screws and pull the bumper out a little and you'll see if its close ( it should be screwed into the chassis with another 2 screws...i swear our cars uses too many screws nuts and bolts)
or undo your indicator light and remove it, look inside you'll see there should be 2 big size14 bolt that bolt something to the chassis, those might have came lose.
or else, the rail frame that holds the bumper (which is the thing the 2 big size14 bolts are for) either broke somewhere
or open ur bonnet, look inside the bumper maybe the bumper is not connected to the frame rail anymore
lol ''flew over a speed bump.. literally flew''
only you are capable of that slim hahaha
have u got a digital copy of the da9 user manual.. it shows everything you need to take every part of the car to peices and back again..
google integra ls or 1989-93 integra user manual.. theres a site that lets you download the zip file for free then you just extract it all and it comes up with PDF files of everything from body to electricals to engine
if somebody knows the website that'd be alot more help
cheers + good luck
