Re: CU2 using oil.
If you ever get the chance, put a cl9 and a cu2 camshaft side by side, you can see the difference in quality.
That aside, the actual problem is the piston rings and piston not matching properties causing oil consumption.
Only way to fix it is new pistons and new piston rings according to acura Tsb
EDIT: read here
http://www.ozhonda.com/forum/showthr...53#post3934653
