This one http://www.corsportusa.com/store/cat...oducts_id=1888
You bought the wrong one? Is that why you have one for sale?
yeh thats the right one.
you can see the rectangular cut out.
it stuffed me over cause the site said the TSX/Civic SI was using the same TB spacer.
but they didnt.
make sure you get the P305R/B/G series (letter stands for colour)
Don't get P309R/B/G/s whatever colour <--- 309 is the TSX series.
And if later I buy a TL Throttle Body im guessing this wont fit anymore? That would suck.
Im going to do this P2R spacer + Hondata Headshield gasket ( already got one) and throttle body bypass.
Then i revisit RBC.
Wheres the best vendor to buy online you reckon?
Sorry i am not sure about the TL TB, i'll check it out.
The RBC should work fine with the civic SI TB spacer + tb gasket.
P2R stuff you can contact P2r themselves directly (www.powerrevracing.com/store).
Spacer can be sourced from Ebay. tb gasket from ebay too.
or you can try K20atuned.com <--- if justin doesn't sell me one, i will source my RBC from them.
you should be able to mod it to fit... i was able to mod my K&N intake to fit, it just puts more bends for the air to try get past, not optimum for power :(
same as above buddy, ill just have a look and we'll try make up a new elbow or something...
if you dont want to fork out the money for a P309, keep your P305 and once you have modded RBC by me and J32A3 TB, youll be able to use that spacer no problems! (my modded RBC has the idlebypass welded shut)
:angel:
Can you explain to a stupid person like me ho that works. So I contacted the Power Rev and they do ship so im ordering.
I fit it to my RBB or maybe the RBC when I get it. Then it goes on my 60mm TB. Now I'm gunna assume the that the hole in the Spacer is 60mm?
So then I fit a 64mm modded TB bought from you and isn't it going to hit the lip of the 60mm spacer? It a 4mm lip around the inside?
Im commiting by the way guys. Im going for RBC, Spacer, TB Gasket, Hondata gasket and TB bypass all at once with Justins help of course. Or as I like to call it "taking J PIS Motorsport"
manifold > Tb gasket > tb spacer > stock tb gasket >TB
depending on what model, there will be a lip about 4mm diameter larger, can cause turbulence <--- i think should wait for justin to correct me but.
are you going to get the P2R K24 IM head gasket too?
http://www.corsportusa.com/store/cat...0K24%20Img.jpg
Yes I just asked for a shipping quote on the p2r gasket and spacer for Civic si as per your instructions.
I want to make sure i can use the RBC and larger TB in the future with the gasket before i commit as otherwise its not a cost effective mod.
