u can actually go search post but yeh
Hence why DACREW Wooo lol
im tempted to go through it and just add the stuff thats in there
if i rele bored one day ill do it
hey amen...there is your DAcrew forum admin cadidate! lol
neither will fit for the front, you can only get one thats made expecially for DA, I am using a camber&caster bolt for DA from K-Mac. doubt you can find them anymore i was lucky to get mine.
you can look at Skunk2 they make front camber arms for DA, ask Yonas @ JDMYard he can get them for you. not cheap tho...but worth it
http://www.ozhonda.com/forum/showthr...ucts-*JDMyard*
on special $395only...$100 off!
as for rear camber arms, eg/dc will fit.
The Skunk2 camber arms for DA are actually ED/EF arms that they advertise as being suitable for the DA. It's a lie and disgusting false advertising.
Unless you're very, very low, a little bit of camber isn't going to hurt your tyres so long as your bushings and alignment solid. A better reason to buy the arms is for more negative camber.
cheers, well main priority is getting my car running at the moment, was just after some options with suspension.
string: i was also thinking that, because we are intercangable with the ED's arent we?
ill probably look in the US market for front camber kits, hopefully ill get lucky.
car will be sitting on its ass, and will need alot of camber for when im done..
cheers guys
jef
@ espinonage "so the EG and ITR LCA pretty much the same?"
no, normal egs and the same as dc2/dc4. only EG6 (jdmcivic) and ITR is the same. Hope you dont get confused.
does anyone have an OEM DA6 centre console/arm rest that they want to sell???
