hondar. one question is..
if i changed to vision bpipe. but still use sotck mufller.
id get the same performance as if i did go with vision b pipee + muffler???
coz ppl say mufffler only make noise?
is this correcT?
is this correcT?
STOCK 2000 CIVIC VTIR COUPE (EM1) - REAR
http://www.ozhonda.com/forum/attachm...achmentid=1282
LEO, I HOPE I CAN GET THIS ALL RECTIFIED BY DOING WHAT YOU HAVE SUGGESTED TO ME OVER THE PHONE. -IAN
MY CAT ON CIVIC COUPE - WITH 6 FIN
http://www.imgmag.org/images/hondar/ozhonda/bpipe2.JPG
AND IAN'S NOTICEBALY LONGER - WITH 12 FIN
http://www.ozhonda.com/forum/attachm...achmentid=1283
IM NOT SURE WHY IT DOESNT FIT...
og5950 has a catback for his sedan (which is same length as coupe), he did not change his catalytic convertor. still investigating... :DQuote:
Originally Posted by og5950
I have one question... Is press bent the same as the crush bent you mentioned?
I am going to get a new system soon and spoke to an exhaust guy who told me it makes little difference on smaller NA motors when refering to press bent over mandrel bent.
Hondar = VTi civic coupe EJQuote:
Originally Posted by hondar
Ian = VTiR civic coupe EM
we have different stock cat lengths? why is this so? can anyone shed some light on this dilemma?
MINE IS ALIGNED, JAYSON WHO HAS EM1 WHO BOUGHT THE MUFFLER OFF ME IS ALIGNED WITH MUFFLER SLIGHTLY TIP TO THE RIGHT BUT WITHIN REASONABLE DEGREE. HE HAS A VTIR COUPE AS WELL.Quote:
Originally Posted by ian
http://img.photobucket.com/albums/v3...r/vision21.jpg
http://img.photobucket.com/albums/v3...r/vision23.jpg
i've got a VISION exhaust on my DC2R but i've gone with an aftermarket catalytic converter (CATCO) and ian you've seen my exhaust in person.
i dont know why your muffler is not aligned.. :confused:
also where did you get your exhaust fitted?
yes, i've seen your exhaust LAGOOT - i like it very much, which gave me confidence in my new exhaust. i really don't know why it is not aligned. I'm gonna check/replace my rubber mounts (maybe sagging).
my exhaust was fitted by a local reputable mechanic who is also a mate (i was under the car during the installation). i hope to get this all sorted soon though.........
that sucks ian, hope u get it sorted man
it seems some traders have had trouble recently with semi-false advertising...
I strongly reccommend on both behalfs, to research the item you are buying/selling to avoid any hassles !
Which axel back does the coupe get? the same one from the sedan ek?
the coupe and sedan apparently share the same axle back (check with hondar). my axle back fits fine on my stock b-pipe although slightly off centre as shown above.
