Your camber sounds pretty ok. Not too bad that it would degrade your handling.Quote:
Originally Posted by spetz
Ok, try replacing the swaybars first. The front is hollow and also too thin. I'd go for at least a 25mm hollow or a 20mm solid one. This will stiffen up the front and give you better steering response. It should fix that 0.5 second steering lag problem. But, upgrading the front swaybar like this will give you understeer, so you'll have to upgrade the rear as well. At least an 18mm solid bar. Go up to 22mm solid, but if you are going for thicker bars, you will have to reinforce your rear subframe to prevent it from tearing.
Swaybars are the cheapest handling mod at about $200 each and also the one that provides a very big handling improvement. So go for this first.
