I can guarantee you the dyno isn't dodgy. And the power figures are correct. :)
BTW, the EG made just over 130kw the same day.
What was the tyre size on your stockies?
They have never had any problems with any other cars and there are cars on there all the time. The dyno shows true power figures, not some of the happy figures that show up on other dynos. Apart from that the ET's and MPH that the drag car runs proves the dyno figures.
And just to prove it another way 2 VL Commodores with exactly the same setup made the same power and run the same times, 1 from Hi-Comp, the other from another workshop. 2 different dynos out exactly the same amount, I don't think so.
I'm not saying your making it up, I'm just saying the dyno isn't out.
I have no idea.
Grumpy Rooster what mods have you done to get 130kw?
It has a standard H22A with a ported and shaved head (comp around 10.5:1). Everything else is standard including the headers and inlet manifold. The only other mods are a cold are feed with bellmouth from the front of the car and a 2.5" exhaust with no cat and 1 muffler. It is run by an EMS computer and datalogger.
Other little things are machining down the balance shafts, and locking them up, no ancillary drives like air, steer, alternator.
In the near future it will be getting some 50mm TWM throttle bodies and new headers.
a typical stock manual H22 is about 105kw give or take a few. Auto version usually have a bit less power.
These are stock figures variance +/-5kw. This is with everything stock
I dynoed mine, JDM prelude ecu, stock engine with CAI , 2.25" catback and got 113kw atw.
mr h22a, you have an accord jdm ecu yeah? as you got an accord front cut is this right? JDM accord engine & ecu combo is 190hp vs prelude 200hp version.
I have seen my speedo go to 190 kph before cut out too.
