A mates using the 17psi one for his Evo, is causing the wastegate to creep on 3rd and 4th gear pulls causing laggy boost. But if its only baby boost like 5psi it should be fine.. Whats your max boost setting?
just quick update, ended up going back to a oem 5 psi one, only because there really wasnt much feed back on these aftermarket ones, an apparently, the more expensive ones Forge racing wastegates are just not worth it.
cheers guys
I use this item and I absolutely love it!
http://www.turbosmartusa.com/product...nal-wastegates
