From what I heard when u jack the car up, if u can move the brake setup and hubs etc up to down it means ur bearings are coming loose. If u can move it side to side that'll be tie rod ends. Some one confirm?
if its up n down and side to side then its bearing, if its just side to side then its steering
hmm.. I might replace the cv shaft, have a mate who's a mechanic and will fit it on for free but I just need to confirm before I buy... will these from an integra vtir be compatible with my Jdm Ek4 SiR?
http://www.ebay.com.au/itm/Honda-Int...df2021d&_uhb=1
can anyone confirm if they will fit nicely? don't wanna have to send them back again....
is that picture of the item?its missing the vibration dampers
ok, i thought that might be affecting his rattle, benjamin can you confirm if those are going to work
i would assume it is.... can't seem to find any other cv's on ebay for my car
i think all B series ones are the same, just makre sure not to install them backwards?
