Thanks Grayfox. I've picked out the relay from Jay cars catalogue. I'll get around to installing it 1 day.
which relay did you get?
Does that relay plug right into the wiring loom or do you have to make the turn off circuit?
If you have to make the turn off circuit
Get some protoboard and some wire and hook everything up.
The kind of protoboard you need which is sold at jaycar(jaycars has round solder points and is brown)
http://www.ebay.com.au/itm/5-Pcs-5cm...item4d34e484ab
The relay(mountable to protoboard according to the spec)
http://www.jaycar.com.au/Electromech...Relay/p/SY4052
Hi, I just recently joined here. Saw your thread and thought of telling you how I did mine. I had the same like what you had from ebay, it fits OK. I just run the +ve wire thru the fender and connected it to my ignition power. No relay or anything else. It's always on when the ignition on. Hope this help.
