andy, do you know what is does specifically?
most people mistake it for purge control of the canister.. because obd1 have them
this device is just between the FPR and the manifold
a lot of people on hondatech say just rip it off
no one has told me what it specifically does (ie no one knows).
in regards to MAF.. or MAP.. the new TB i have has one..
all i need is a line to the booster and FPR really
ok, as always i like to reply to my threads when i have come to a conclusion..
Basically i removed the device, it went between the FPR and the manifold..
it is known as a Fuel Pressure Solenoid.
If i recall correctly there is no corresponding ECU light for this device so it doesnt seem like a critical device. I guess it will block the line between the FPR and manifold when the ECU tells it..
i have had it removed for 2 weeks now with no real dramas.. AFR's seem fine too!
