Well, tell us the exact capacity of both engines. Let's assume your standard engine is 1598cc ( for example) so you times that by 1.15 to get the maximum capacity replacement engine to be installed. Which is 1837cc. The b18b , and all b18c variants are under this capacity.
This means, your brakes are sufficient for this engine increase of capacity and don't require engineering. If you had a 1.3 breeze you would need to upgrade brakes for example
