Excellent.
Going to see if I can regrind the cam to increase lift and duration (through magic. Or just get one made. however it works). So, y8 springs and retainers? And maybe valves?
buy a y8 head can get them for 50-100. buy PG6 pistons. oem d16y8 headgasket and you will be in the 12:7.1 comp area.
http://www.d-series.org/forums/engin...tml#post142991 have a read threw those
PM me if you just want a d16y8 motor cheap. Comes with new belts/major seals + water pump already done.
Doesn't have anything on d16y4 block though :(
Or would the 15b7 be similar?
Did find something else on it though, and apparently it's a pretty straightforward swap. Sounds promising
edit: If I go with the y8 above (which I more than likely will, if I can get my funds sorted), would the pg6's still yeild that high compression? They seem to say (from what I've found on ebay, haha) that they are close to stock compression. Although, that is for a d16a/ some others. all whilst saying high comp. Iunno. But, that could be a good way to do it.
If I'm pulling out the pistons, may as well replace bearings, may as well get the block honed and what not, get crank journals checked, etc.
probably go brian crower stage 2 na cams. Maybe with valvetrain, if need be.
That should make it a bit of fun. And also in theory make the engine last. As much as it's got new bits, if I'm pulling it apart, may as well do it fully, so it lasts a long time :D
