send ECU-MAN a PM
what happen to your ECU ?
Someone before me had attempted to bypass immobiliser. Their solution was ripping off the pcb chip and the resistor, and did an awful job at bridging j20. When they did this, the solder had joined with the resistor on its left and this hot qld summer has been reeking havoc on it. I've looked at it closely and it appears to have some of the lines ripped off. I only assume they've dropped some solder, when they've gone to remove it they took more than just solder.
Ecu-man. How well will a p72 run with an obd2a ITR b18c7??
it wont run it at its best, I don't recommend using it.
if you cover postage costs Ill fix your P73 for free
If you don't mind that would be awesome. Mind inboxing me your address and I'll send it off this week.
The lag issue seems to be related to my ecu. I've installed another, and it seems to be running fine again. Thankfully ecu-man will be taking a look at it for me. I'll have an ecu-man ecu!!
I've put ecu man on my " Mr Nice Guy " list.
