Technically the iacv motor should compensate for this and increase the rpm to the setpoint. Maybe this is faulty.
It is worth turning it the other way, maybe 180 degrees and see if it increase the idle.
..have you reset the ecu yet?
Take it to genuine Honda dealer
Prepare visa for workout
user mocchi would know the answer but he not online anymore :(
what state? if nsw go and see BYP racing,theyre honda gurus
I'm in Victoria. But central/north.
Just reading more. According to the shop book. There should be no suction from lower port after warm up. So FITV is dodgy. But since a working valve restricts air after warm up, would a broken one give me a high idle, not low? http://uploads.tapatalk-cdn.com/2016...50c0635fbf.jpg
The more I read the more I think IACV is culprit. But apart from cleaning it, things I could try are changing gasket and checking electrical connections.
My gut feeling is also a faulty iacv.
If you turn it anti clockwise 180 degrees (you could try a full turn), it should manually let air through the engine and increase the idle rpm. This is not going to fix a broken iacv but will make the engine idle better.
Thanks, man. I will try. Have ordered the little 'figure 8' gasket and will get the multimeter onto the connection when I get time. These suckers seem to be quite expensive to replace. And I've been burnt before buying used replacement parts. Ah 90's car life!
Sent from my iPad using Tapatalk
This will be a great learning curve for you. I went through the same thing.
Calibrating the tps sensor wouldn't hurt.
Definitely replace iacv.tappets,timing,it's not hard.learn it all,know your engine. Then you'll be the one giving advice.
With the electrical load lowering the idle,a mega raizin is awesome. Watch out for ebay copys..
good luck mate.
