> yeah the injesctors are black tops, they flow the same as the blue tops
Blue tops spray in a single cone. Black tops spray in a dual cone pattern.
Otherwise same sameness.
> I've seen the vitara pistons but in the D16A3 motor i have they yeild a very low
> compression ratio due the the much larger combustion chamber
I think FJT distributors now do a longer conrod which recovers a lot of the lost compression ratio.
If you've access to a machinist, it's supposedly possible to rebush B18 rods from 21mm to 19mm piston pin. They are slightly longer than d16 rods and are another route to recover the lost compression ratio.
I THINK it may be possible to source YCP Vitara pistons with a 21mm piston pin.
YCP make Grand Vitara pistons which are 75mm, 21mm wrist pin. But it's a long time since I looked at that stuff.
nothing wrong with forged pistons though.
Nick.
will be very interested in this build, and especially the power it results in, personally i'd think 150kw to be a bit of a stretch (esp for any extended period of time) but i'd love to be proved wrong!
yeah i assume 150 will be about the upper limit on higer boost before i blow something up, i wont be running it like that everyday. And once its all running im going to start saving up to forge the bottom end and maybe sleve it if i want to have crazy power levels, we'll hve to wait an see.
Yeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeeeeeeeeeeeeeeeeee
eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee ees
Got more done today
Put the fitting in the sump and sealed it up wiht high temp sealant
http://www.redpepperracing.com/gallery/d/239538-1/1.JPG
http://www.redpepperracing.com/gallery/d/239541-1/2.JPG
Then got the intercooler in place
http://www.redpepperracing.com/gallery/d/239544-1/3.JPG
Start of the intercooler pipes, all made out of mandrel bent aluminium.
http://www.redpepperracing.com/gallery/d/239547-1/4.JPG
http://www.redpepperracing.com/gallery/d/239550-1/5.JPG
http://www.redpepperracing.com/gallery/d/239553-1/6.JPG
http://www.redpepperracing.com/gallery/d/239556-1/7.JPG
How the filter will be postitioned, and the box is the same size as the battery im getting so its just there to make sure everything fits.
http://www.redpepperracing.com/gallery/d/239559-1/8.JPG
How I modified the black box to remove the PCV valve, ill be running this straight to my catch can. This thing is a PITA to remove as well.
http://www.redpepperracing.com/galle...39571-1/12.JPG
http://www.redpepperracing.com/galle...39568-1/11.JPG
And its off to the exhaust shop tomorow morning to get the dump pipe and exhaust made up and all the intetrcooler pipes welded up. Its getting a 2.5' mandrel bent the whole way back with a resonator and muffler.
Cheers
Luke
hell yes! AH all the way!
coolies i saw the car today, looking good!
