cool dean. Thanks man :thumbsup:
I'm starting to think that my oil pressure is ok. At 3000 rpm i'm getting around 50-60 psi (depending on oil temperature). The hotter the less pressure i get.
Just the reading at idle is a bit concerning.
Can anyone shed any light on why oil pressure would be reading on the low side? Too light weight oil? or a pump thats not performing to spec?
and would adjusting the pressure relief valve be a suitable fix? or is it just a band aid solution to a bigger problem?
