On the topic of future ozhonda-ers, and also google-ers and yahoo-ers heres my list of parts needed for the swap - to my knowledge:
1. b18b Engine and transmission (w/intermediate shaft) - get same OBD engine as your cars current engine to make thigs easy
2. Ecu and iacv connector (Might not need the iacv connector, leaning towards not, as both d16 and b18b are non vtec, could be wrong, still researching. theres either a 2 pin or 3 pin connector, if your d engine has the same amount of pins (in the connector), as a b18b, then its not needed.)
3. Shift linkage from integra (maby also shifter, but out of the tons of "parts for swap" lists ive found on the net, only one old old site includes the shifter as a needed part. Waiting for JDMtype R's responce. Find it odd that maby 20-25 people forgot to mention the same part in other threads on the net tho)
4. Appropriate motor mounts
Rear Tranny mount from the 99-00 Si: 50827-S04-N10
Driver side mount bracket from the 99-00 Si: 11910-P30-000
96 del Sol AC bracket: 38930-P54-000 ( only if you want to keep your ac)
Integra front tranny mount
(see http://kosmo.homedns.org/trey/6gen/ for more detailed info)
5. B series axels
6. B18b header (b18c header might fit, no idea on compatibility)
Edit: 7. Intake manifold and such, of course!
I feel theres more things needed for the swap, but this is what ive found so far.
If anyone can see somthing missing, or incorrect, please chime in!
Now, back to my questions lol.
