Just check if it has bent from time to time,more bars the stronger.
so wait, what are you telling me to do?
put another bar across the other bolts, i got that much, but then what? across the back, under where the boot is?
I'm not telling you to do anything,just suggesting.
I think a bar next to that one making it 2 there and a bar at the rear.
FUUUUU!!! soo gethoooo lol.. is a damn good idea.. lol.. +1 rep for u mate..
WD. hope it works as good as one you can buy. :confused:
very creative.. i like!
i think you have gotten confused by beeza's suggestion. the bar across the back that he talks about is not in the bottom of the boot near the spare, its on the inside of your interior trim on the back of the boot, near where you would change you tail light globes.
if you take off the plastic trim covering the inside there you will see x2 holes accross the back of your boot...i think that is where he is suggesting a bar could also be good
TECDUP: yeah thats what i was confused by. thanks.
i would like to say its as good as a brand name one, but i havent really used a brand name one to compare.
That's it!
probably works better than those stupid egay bars with a single bolt at each end holding some hollow bar to some mounts
good work mate
do not watse your time with those ebay ones. this would be much much much better
why not fill the pole with some expanding polyfoam? would stiffen things up more i reckon... i've seen it done when chassis tuning, this would be no different.
