Originally Posted by
Davo
IEVAQ8, the 2 setups your comparing are quite different. Using and internally gated t28 turbo with a .86 rear housing, smaller exhaust and log manifold to a externally gated .82 rear housing 3037 with larger exhaust and tuned length manifold. naturally with a smaller rear housing, external gate setup and bigger exhaust and tuned manifold you would reduce lag considerably.
i originally had a GT28R on my 180sx. with the exact same setup and only changed the turbo to a 3071R with the same Comp housing and same .64AR t28 rear housing, the turbo was laggier (not by much) but yes it definately did make more power.
on both setup were you running the same amount of boost too??
