Fujitsubo in stock here
On spot fine is 20k if you running no cat......
You do realise you are allowed to get an aftermarket exhaust cut and welded to fit a cat...
contact adrian @ toda for your headers quality stuff
which will include headers + cat + ep3 sway bars + heat shield and all that, fitting, dyno before and after runs.
and contact yonas @ jdm yard for your fujit cat-back + injen cai! cant go wrong here, you will pull some good numbers high 13's with good driving.
and you may want to upgrade your clutch while your at it, it will be worth it for the long run.
