goodbye door trim varicose veins!
http://i19.photobucket.com/albums/b1.../doortrims.jpg
DO-A-WRITE-UP
EPIC win is EPIC
Yeah I did notice the write up but it needs more detail and to be in the DIY section!
Cheers, I will have to give this a go.
Oh yeah what brand or sort of clue you used?
Where you get it from?
I used bostik contact glue.
See here:
http://www.bostik.com.au/browse.php?cat=DIY%20Adhesives
Third one from the top. You'll find it at bunnings, clark rubber, and i think even Big W.
read the instructions carefully. contact glue isn't a 'apply and the press together immediately' type of glue.
You'll need to get it on both surfaces to be glued, then wait 15 mins, then press the parts together. the glue works by sticking to itself.
After pumping the glue through the door panel, I pressed the vinyl down to essentially ensure that both surfaces are evenly coated. Once you remove pressure the vinyl will pop up again because the glue hasn't dried enough to grip. The 15 minute wait after this initial application is important.
Now after 15 minutes press the vinyl down and apply even pressure. It should stick perfectly.
I'm waiting for when I have the time to take fully detailed photos to do a proper writeup. It's funny how all the old threads on team integra have talked about it and no one figured out a proper answer.
Might have to try this on my dash, lol
