Originally Posted by
CRXer
bottom hose still wont drain the water jackets,thermostat is still higher up.
if u dont want to jack the passenger side of your car up 90deg,u gotta remove the drain bolt(just next to the engine number btw) & has crush washer not an o-ring,use some sealant on the thread as well.
strings right its a bitch to get loose,u need like a lever socket arrangement that u can hammer on.
i think u'll find most people dont even bother draining the block,even the shops,the shops prob just flush new coolant thru the block,if at all....
