Whale penis intake are just CRAP.
Avoid at all cost, unless it is the look your after for your engine bay.
As mention above intake from Injen, AEM etc give good bang for your buck performance gains.
sound?
very very LOUD. and angry...
torque?
felt weaker than my stock intake before crossover.
But had a very aggressive crossover, which was probably because the torque curve before crossover had dropped lower than stock...
but dont take my butt dyno as bible... as maybe inconsistent from time to time from lack of roughage
power?
If anything, i'd say it had pretty good throttle response and city-block-wakening sound effects...
ok ppls, i have steered away from the whales penis and just modified my SRI to a CAI, running a pipe all the way to the front bar and making a vent and making a sami inclosed box, i find it a lil more torque, and response aint really changed but the intake doesn't sound as loud as before, but thats maybe due to it been further away from me.. im happy with the results :)
i just purchased a cheap crappy one off ebay ... ill let you know how it goes lol
93 honda civic gli sedan (EG - D15B7), currently has Dc2 Integra Vti-R intake arm with a Apexi pod on the end ... which is actually awsome ... sounds good and revs quicker than the stock arm with K+N pod
the apexi pod is pretty dead and i needed a cheap quick replacement so i purchased a no-name whale penis with pod system from ebay lol the car is just a run about so im not chasing any massive gains or anything ... just want a new clean filter thats not damaged and the kit i purchased looks nice and ordinary as well =) not after anything flash lol
ill let you know about the changes when it arrives =)
I don't think big brand names are really worthwhile. AEM, Injen, Fujita etc...they all look nice and shizzle but at the end of the day there's not a lot separating them from a random piece of 2.5-3" intake pipe.
If you just buy an APC SRI and get some more pipe, silicone connectors and clamps etc to relocated the pod down in your bumper you'll get a very similar result - it just won't look as 'nice'.
And in my opinion having used both alloy SRIs and the whale penis I'd say the whale penis is just a fancy looking SRI at the end of the day.
So really...just play to your budget and aesthetic preference.
did anyone notice the whale picture on the previous page showing a real whale dick. omfg, gross
been tested.. OEM air box with k&N make the same power..
OEM air box makes more KW than the whale penis copies.... too haahaah
POS..
u better off with the right size ebay intake. or something from AEM or something if u are after sound
i recon a good whale penis is designed to give 'cooler' air. when the air is sucked from the air filter, it being expanded in the whale penis to lose heat and producing 'cooler' air. and then compressed at the throttlebody. even tho the heat generated during compression on the throttle body but it will still slightly cooler than atmosphere temp.
I know you may say the air within it is almost in vacuum condition. but because of this situation, it allow the air moving quicker through the whale penis and producing cooler air. just like wat ur freeze did. compress and decompress to generate low temperature fluid.
a branded whale penis will taking the air velocity, temperature, direction, turbulent /laminar flow into consideration while the copy just simply producing similar product without consideration of the properties of moving air.
It just my though.
I dyno the whale penis..I might not of done this right but I ran the car with whale penis and then just a bare throttle body ( no filter) .. 0 perforance gain,,,( they do make a great sound though) I use AEM now,,filter in the front guard ,,have not dyno it
