Hey,
just wondering, did you use the jdm DC5R flywheel and a accord euro exedy heavy duty clutch, or did you use theintegra heavy duty clutch. And how much the cheapest you reckon i can get a jdm flywheel for? any suggestions?
Thanks
Sorry to dig up the past, I'm looking at the Exedy Billet flywheel (this one as an example: http://jdmaccessories.com.au/?produc...acing-flywheel ).
Just wondering if I would need to replace the clutch if I was to get the flywheel designed for k24.
Cheers for the help.
Dale(stillanoob)
I used jdm DC5R flywheel - too light flywheel isn't very friendly ;)
Using K20 flywheel will open up more options to clutch kit replacements. If your stuck and on a budget AUDM K20 flywheel will suffice (lighter then EURO). As for clutch, heavy duty or sports organic if in doubt go for OEM replacment (it will be dependent on application you intend to use the car)
Yeah I am on a budget LOL! You guys picked it, so what you're saying is that it's not worth doing the flywheel on it's own?
I just figured the Exedy one would be a direct swap because it's listed as suitable for the k24, if it wasn't you could use just about any flywheel or clutch couldn't you? (Provided the basic sizes worked)
I guess my question really is: What is the best budget lightened flywheel I can get without changing my clutch?
Thanks as always,
Dale.
