shot wheel bearing possibly?
Jack the car up, and try to jerk the wheel back n forth... if there is play, get your wheel bearings checked out.
ok problem has come again
only when i hit big bumps . the screws start to come loose im not to sure if its the wheel bearings or whatever but i have taken photos of the screws and the holes i was wandering if anyone knows the length of the bolts that i have taken photos of just incase if there longer i might have to get new ones
http://i258.photobucket.com/albums/h...3/IMG_0570.jpg
http://i258.photobucket.com/albums/h...3/IMG_0573.jpg
That's the right length. How are you tightening it? You can't get enough torque with a normal screwdriver. I do them up with a hand impact driver or a battery-powered driver. Make sure you use some loctite.
what loctite should i use? ill have to get some tomorrow man also ive tried tightening them up with the impact driver but it seems to come loose so easily
bro goto a mechanic n get them to back off ur hub nuts lock tight them then tighten the shit outa them with a rattle gun.... happen to mine and it happens to alot of IRS or front wheel drive cars.
Yeah, good idea to retighten the hub nut as well.
