i had the same issue - replaced the bulb and worked fine. hope this helps
Quote: Originally Posted by fusionprelude could be wiring issue or flasher relay playin up test the switch circuit in the relay.. also bulb could be about to blow causing more resistance You're spot on mate, the rear left bulb was damaged but was still working. replaced it.. all good.. cheers
