the answer is directly below is post.
its fine
as the emissions are the same, its about the emissions, not the year make of the engine
its fine
Yes b18 from 97 teg can go into 00 teg shell
Back to OPs question, i didn't say u need one, but it's best to get one if ur thinking of doing alot of Mods to ur car. Engineer Cert costs between $500-700... therefore it's best to do all the Mods first like I said then Engineer Cert ur car. It will also depend on the popo that pulls u over, they will look for something they can defect you on (from pods to rims ansd even tyres...)
Remember money cannot buy that peace of mind while U drive!
correct me if im wrong im pretty sure it depends which state your in as the increase in displacement varies...
Yes it does depend on the state. How about u call the transport authority it your state to confirm it for you.
engineers certificate for b18c? are you turbo charging it?
what a waste of money.
you want piece of mind? mod your car properly.
1.6L to 1.8L just needs a blue slip.
You can also put example say a 96 spec itr motor in a 99-00 model car.
didn't I say that the OP doesn't need an eng cert. for 1.6L to 1.8L, in NSW that is I dunno in other state... but if he want's to do more upgrade (turbo or non turbo) then having an eng cert. would be the safest way.
...when U said "mod ur car properly to my quote, if U want peice of mind"
that means changing suspension, bigger brakes the list would go on and on, just to make your car not only fast but handle the power.
you gotta remember to do this U would have to change factory parts and settings... and what would most popos say "if it's not original it's DEFECT:p
nahh you dont need to have engineering certificate.. your only upgrading displacement by .2
AFAIK.
from 1.6L to 1.8L
QLD - Need Cert (10%)
NSW - Dont need cert (15%)
VIC - Need Cert (10%)
dammit being in melb sucks balls ty every1 tho
