C-clip on the end of the shaft?
thing is i need a diagnosis before i spend more money removing and replacing things that isnt the problem :(. when are you free ben?
dont look at me im in Japan sorry mate :)
As fatboyz said above - the C clip on the driveshaft MIGHT not be engaged and the driveshaft is slightly popping out upon driving - but you would be losing gearbox fluid if this was the case as the fluid leaks out of the non-sealed area. Note any fluid loss.
Perhaps one or both driveshafts are not overly held - 32mm hub nuts are loose might need a tigthen - or even lugnuts arent 108nm or so tight. Check it all that you can Sam.
Try TODA AU
or HANNYS 9725 5115
ohh so that explains your phone being unavailable all these times when i had engines and gearbox jobs lined up for you lol.
okay im hoping its only just that, thanks heaps dude, will go to a local mechanic to get the shafts cheked out
Pop round on Sat if you havn't got it diagnosed by then & I'll have a look.
It could be as Ben described or something dumb like an inner or outer CV being a little rooted & binding up, that can also present similar symptoms.
We're up @ Thornleigh now though.
Cheers
Adrian
ohh okay cool, will call on your mobile to make sure your available
bumppppp new informaton
