Is it possible to get the side bolsters retrimmed to match the rest of the seat? Would the material be available from honda??
The website www.capitalseating.co.uk used to sell side bolster foam for recaros and any trim shop could fix them up.Quote:
There's actually an Upolstery cleaner made by Maguires that I usually use. It comes up great!! You simply just spray on, leave it for 5 mins, then wipe it with a wet cloth. My seats look brand new after every application. But 1 thing to be careful of is not to use it too often. It does cause the colour to fade a lil bit. The spray costs about $14 from Kmart and it's definitely worth it for every Recaro owner :p
Might add my worth to this thread, I hope all you guys know that the seats are interchangeable. That is the passenger to driver and vice versa. Ideally you can swap them around if your mainly a solo driver to get an even wear into them. The only tricky part is getting around the seatbelt sensor but its an easy afternoon job to keep those recaros looking good.
STIG. try a frozen cooler brick for the bubble gum hold it on there a try an freeze the bubble gum thats how you get it out of floor matts stick them in the freezer.
is it safe to use a gerni on recaro seats to clean them??
obviously taking them out of the car then leaving them in the sun to dry??
