Out of those 2, i would say ELF. I generally use Royal Purple and Neo oils.
nulon is a higher grade then elf and if you want a high grade oil look at amsoil royal purple
at the end of the day,, all oils have been engineered, there are companies out there who make same quality oils for different other companies,
but personal preference extra
thanks
The oils have a standard they have to meet and those are updated reasonably frequently.
It's all much of a muchness.
As long as your using a name brand with a preference to synthetic you'll be fine.
But I run Nulon because they are Australian.
motul 300v :P
im using nulon 10w40 atm and i dislike. might evn drop the oil early. burns quicker then any other oil ive used
How much is quicker?
I previously used Valvoline Durablend 10w40 and it burns pretty much the same a Synpower 5w40...
Back to FEO 10w30 now and it still burns the same...at least it doesn't burn quicker.
O.o
I'm over it..Simply use 5w/10w/30/40 weight oils in your Honda...I feel like i've wasted so much time testing half dozen oil. lol.
Stay with FEO or choose another popular brand, it's personal preference...changing the oil every 5000-7500km is more important.
Well ATM I've driven around 2000kms and have added in 500ml so far, 5w30 castrol used less, mayb 500ml every 3000k
Go back to edge 5w30...it seems to work fine in Hondas and many of us stock up when the 5L litre bottles are on sale @ $35-40
lol
Prefer Elf. Been using it since for the past cars I've had and runs well, not much oil burn and reliable.
Recommend (Y)
