running stock headers and cat btw
just an update, my obd2 reader finally just magically worked and was able to read the code, showed up P1166 and P1167 which was in relations to the primary o2 sensor
with a bit of digging around on the interweb in the past few weeks, you had to clear these code for the CEL after the primary o2 sensor install using the obd2 reader (ecu reset wont do the trick), did that just then
will run the car tomorrow morning to see if its all fixed cos its a bit loud and dont want neighbors to get pissy
so in summary, all i had to do was clear the codes using the obd2 reader... hopefully
Well i had my engine light keep coming up but i'd turn the car off and it disappear and wouldnt come back
Yes i know im resurrecting a thread but unlike most people i searched :)
Thanks ChargeR for this as i reset my ECU and atm the engine light hasnt come back on but ill assess again tomorrow
+1 Rep :)
BTW guys/girls, if you have a CAI or whatever, make sure you leave your car running for at least 15mins so the ECU can run in your mods alright.. thought i should add that
sickest guy bro cool
