Ya found the insulation to be pretty neat job from Honda. Only complain is that window rail sitting in the way of the speaker opening at the door. :(
Pretty surprised with the amount of screws (5 in total) used to secure the door card.
hey guys im looking for a fascia for a after market dvd player sick of the standard head unit any ideas were i can find it tryed all the car audio shops cant find them no were
Not sure if it was your pic of not of the pioneer dvd player? how'd did you do that?? looks crazy i have had the dvd player siting at home for two months waiting for the fascia to come out
Said8u pm me your email I'll send u some info on my fascia kit. Replaces standard stacker etc
Hey mate, neat install.
Just after your thoughts on the SOEM4.
Also, why did you use one anyway? I thought the Focal had speaker level inputs, therefore, a LOC isn't needed?
True enough, the Focal amp does indeed have speaker level inputs. However like most LOC's they use big resistors to attenuate the signal. After doing a lot of reading on this subject, and learning that Honda's can be notorious for introducing noise into the audio system, I decided to go with the SOEM4. These units, like the "Peripheral SVEN4" that was it's predecessor, use transformers and therefore do not present a huge resistive load to the factory amplifier. Also, using transformers and DC coupling effectively eliminates all noise from the system, providing a very clean RCA level input for the amp.
No doubt if I had tried the high level inputs on the Focal amp it would probably have worked just fine. But I am very pleased with the performance of the SOEM4, it does a great job.
Cheers.
Thanks for the reply. Very fair answer.
I've never installed a LOC before. Did you need to tap into both the front and rear speaker wires, so you have '4 channels'? Or do you only need to splice into a pair of speaker wires?
Reason I ask is because you tapped into the signals right at the stock amp location, instead of just doing the simple route and taking them from the rear 6x9s.
Yep, I spliced in to the factory amp output and used 4 channels, both front and rear. This allowed me to retain the full functionality of the headunit, including being able to fade Front to Rear as necessary. However, it is certainly technically possible to use only a two channel input with four channel output from the amp. I just chose to keep all four channels separate.
Cheers.
Again thanks for the reply.
What are the other features that you retain if you do splice into all 4 channels? Besides fading?
I am planning to run just front splits and a sub, so if it's just being able to fade front and rear, I believe I won't need to do this? :)
Hi again mate,
When you installed your SOEM, is the remote wire (blue) connected to the remote input on your amplifier?
Does this bypass the need to run a wire from a 12v that turns on/off with the car?
Simply put, the SOEM takes care of pretty much everything? If so, it looks like it's worth that lil extra compared to other LOCs.
