So far, I still don't have any problem with my CVT but it's not as smooth as I thought I would be
pm sentQuote:
Originally Posted by TypeG
i have the same issue as u, that's y i've been asked them to change the cvt gear box oil when i done 20000kmQuote:
Originally Posted by terris08
which is better after the oil change....:thumbsup:
It is the most obvious sspecially when you suddenly remove your foot from the acceleration pedal. It has the sort of engine break effect which suddenly slow down your car and if you depress the pedal again, it then suddenly 'rock' to accelerate again....:thumbdwn:Quote:
Originally Posted by brightboyfree
So uncomfortable when attending early lectures and stuck in the traffic in which you have to run the car at low speed and start-stop all the time.
If u found this happen in a auto Jazz, i think that is normal as another other auto car. Coz' when u are driving in high speed, and suddenly release the acceleration pedal, the computer will help u to change to a lower gear. so u will feel a "sort of engine break effect". Then u press the acceleration pedal again, because the car is still in lower gear, so it give more power to go forward, and it let u feel "suddenly 'rock' to accelerate again"!!Quote:
Yes! Jazz is more sensitive then others! i found it change to lower gear faster then other auto car! Sometime it let me feel uncomfortable either!
Acutally, this is the different between driving auto and manual. You can let the auto to change gear (to get more power) by release and then press the acceleration pedal again.
edited title to reflect on idea of topic. :)
Yeah I heard there are some problems with the CVT while I was oversea.
my friend had to change his Jazz wheel bearing only after 60,000kms
but all cover by warranty hehe.
Oh, I guess not that serious with mine....just a little bit not too smooth, that's all I feel
Which oil do u use?? Original Honda??? I found out that with Honda Civic CVT, normal dexron III can actually be used for the Civic CVT instead of the original Honda oil. So what i am thinking why not for Jazz??? Should be the same, both CVT. If can use, then it would be nice cos there are many fully synthetic dexron III gear box oil around.
Not so smooth as in you can feel the gear change or not smooth as in when you take your foot off the accelerator pedal?
Like I said in one of the thread, I am experiencing this funny noise when in "R" gear when the engine is hot... Getting this looked at Thursday and see what they say. It could be I am a bit over-sensitive.. :D
Found out that the noise is characteristic of the CVT reverse gear... I am still a bit doubt about it as I can hear some occational squeak noise in reverse gear... Anyway, I am waiting for it to become more constant before I take it back to Honda.
One question though.. I know the red line is at 6500rpm and the car is designed to be rev (vtec) and redlining. I understand that Honda wouldn't have set the redline at 6500rpm if the car is not capable of... BUT... if rev too much between 3500rpm - 6000rpm, will it shorten the life of the tranny or develop more problems with the engine?
Quote:
Originally Posted by DavidLing
but it happens on me even only 20km/h...........
