EK4 comes standard with sunroof. That would probably be the extra weight and that weight is right where you don't want it, up high.
I think these needs to be addressed at the next track day.
I want to see standard EK4 Vs. standard EM1 lap times.
As for the flex issue, if the wheelbase is the same there’s the same area between the wheels on both cars therefore the cars will both flex the same. If the ek4 was fitted standard with the rear bar like the Civic type R then there would be a difference. The fact that there is a solid rear parcel shelf in the coupe rather than the hatch cover means the rear end may be even stiffer, but that’s me speculating
