the es1 and eu3 tie rod ends are smaller than ep3. the bolt that the cotter pin goes through that is.
Can we order the tie rod end for em2 from any honda dealer or i have to get someone to order for me from japan?
em2 is the 7th gen coupe. we don't get them here, i think it's only in us and europe.
hmm.. im just saying, im not sure if they are going to fit since they share the same suspension parts with the ES and EU we have here. if anything you should've probably got the ep3 si tie rod ends from the US.
Apparently the taper size on those can vary from the JDM models. Not sure how true that is. Otherwise buy a Type R tie rod from the uk, they are the same.
I found a place that sells them in the uk I am just waiting on postage cost, If anyone wants some OEM Honda ep3 type r tie rods i will buy a few in the one order.
Reviving thread. I need to replace my LH tie rod end as it's busted after coilover install. Anyone know where I can get this part over the counter on same day? Or is this part only available overseas?
