Out of all the links from google, this was by far the best step by step instruction link:
http://squeezer.net/s2ki.com/S2K_Valve.pdf
Like I previously said, I cannot access youtube at work - but its definitely worth while doing so before you start this - especially if you've never removed your rocker cover so you're not in for a shock!.
Tips:
Removing your air box is as easy as pie - but it takes longer than removing your rocker cover. Also, have a system so that you know where to put what when re-installing everything - I accidentally put my vacuum hoses the wrong way, and after doing the adjustment heard this weird ass suction noise. Once again, I searched this on you tube and found out my mistake!!
Make sure your car is in neutral!! otherwise you might run over your foot wen turning the crank shaft!
Also,
I ordered these from Honda before I started any work:
- Head cover gasket
- Head cover washers
- Rubber seals
Can get these all from Honda for $98.
If you have all the other tools - ther rest is priceless ;)
