Doesn't matter what headers you run but make sure you run a cat
good high flow cat lyk toda can flow as good as straight pipe,
toda headers > spoon headers
for street, cat is a must, not worth the risk of a mega fine etc also, I would def stick the the TODA headers as well man, for sure!!
but look at it this way, thats one less person that will be running cat'less, somewhere else someone else could be contemplating the exact same situation (cat or no cat) then ONE person says "it is so bad for the environment."
but if no one said "it is so bad for the environment." u would have one more person adding to the green house effect.
repeat this say 100 times and u have 100 less people running cat'less.
see the point there?
all it takes is one person
those 100 peoples effort of buying the cat is destroyed when Gillard flys in her leer instead of hopping on a bus.
all good guys, but i think the issue that most concerns the thread starter in regards to cat or no cat is the massive shit fine he will get if he gets caught without it. No cat might get you estimated like 4kw's at the wheels at most for a pretty much stock car. Not worth the risk.
That doesn't mean you shouldn't use a cat.
Don't point the finger at other people, just take responsibility for your own actions.
Would it be fair for me to say it's alright to kill a person because somebody else killed 10,000? Of course not...
Just do the right thing and use a cat...
touche
at the end of the day, its his car, an if he decides to go with the no cat headers, than thats his choices, we all did our part, by sayin no to spoon headers with no cat integrated into it... just dont come running back sayin how u got a massive fine an epa letter for no cat use
