James, that mean setup for the street is overkill in parts dont you think?
the average joe doesnt spend that sorta money on a street car all in one hit bro.
It would be better to list the parts that he needs in terms of non branded or generic things, ie turbo manifold, dump pipe, injectors etc.
But for 6 psi, Id just use a small turbo t25s or t28s even up to t3 are good for the street, use an internal gate on these turbos (which most will come with 6psi springs). Manifolds, u can cheap ones made for 600, avo's cast ones set u back about 800, get a cheap intercooler, evo/vr4 ones rock, bov (turbosmart, or whatever cheap brand, hell dont even need one, just ask powered by honda), fueling u can go the cheap 1 injector, but id go 4 rx7 injectors or other big top feed injectors, drill into the fuel rail, and get a good computer to control it all.
fuel pump and fuel reg? its honestly not needed at 6 psi, when i ran the lude, it was sweet, and never ran outta duty cycle at 6 psi, i was running stock injectors at 5 psi for abit.
at 6 psi ud be surprised but ur VTEC/turbo is quite fast :)
