vtec killer cams dont have vtec lobes.
make sure you take account of supporting system to achieve peak hp e.g. 4-1 header with long primaries, larger diameter. shorter, larger diameter IM.
not sure in the relation in valve overlap in terms of choosing camshafts. also, dont forget dynamic compression ratio, larger lobes will reduce static compression ratio?
street car needs torque i very much agree.
Yes true, but I didn't want anything extreme that would make my idle rough or mess up my fuel useage too much. I drive the car once a week and it gets rev'd out quite a lot, so the stage 1 cams were IMO a good choice for what I wanted out of my car.
Being a 1.6L I'm not too concerned about how much low-end power I'm getting. It revs out to 9,000RPM and there's plenty of power to be tapped into :)
hey dougie,
what is this stage 1 cams? what makes them so called a stage 1 cam?
Youll find the terminology of "stages" used to descibed cams in every single motor ever built.
Its just an easy way to describe how much more aggresive over stock they are. Normally they go in 3 stages.
Stage 1 is a street upgrade, basically a little bit more lift, a little bit longer duration, adds a few more HP and a bit more torque without the need for tuning, and without making it totally unstreetable and shit on fuel, a pig in traffic etc.
Stage 2 is for those who track their cars often, a weekender or once a month car, but still needs to be reasonable in traffic, and on fuel. Duration and lift are increased a bit more, generally helps to have something to tune to, and you wouldnt do it without having all the supporting mods, intake, exhaust etc
Stage 3 is generally regarded as race only. Massive lift, longer duration, moves the power well up in the rev range, results in the under lump idle, shit on fuel for daily driving. Really only useful with a complete aftermarket computer, all external mods, and internal stuff, valves, valve springs, retainers, all upgraded.
i think we should refrain from using such terms.
http://www.team-integra.net/forum/14...-get-next.html
i agree more to the link above.
spetz: check out this link http://www.team-integra.net/forum/14...-learning.html
be wary in choosing cams. make sure it suits your needs.
Sorta but not really the same. That thread is Reffering to stages of total upgrade packages. Just like what youd see in Gran Turismo or Need For Speed, especially the old underground/underground2 games.
They imply that a "stage 1" intake is say, an aftermarket panel filter, and will net you 5hp everytime, no matter what other supporting mods youve got. "Stage 2" is a pod and a CAI and will net you 10hp everytime, no matter what. etc etc.
This sort of talking about upgrades has only really been prevalent since the real upcoming of the "import" scene, say the last 10 years or so.
The idea of "stage" cams is one that has been around since hot rodders in the 50s, and simply refers to how much more intense over stock the cam is. There is no indicated amount of hp gain, and manufacturers will state they they will only produce a gain when combined with correct supporting mods.
Also remember 'stages' are different for each aftermarket company. I think Buddy Club's 'street upgrade' cam shaft is referred to as stage 3, similar to Skunk2's stage 1.
If you're looking at shafts you just have to see who has what to offer, but that's generally the case as trism stated.
The BuddyClubs are Spec III.
i agree with you. cam manufactures should be forced to represent their spec's in ramp, lash, duration and lift. and take the time to find out the dynamic ( not static ) compression created, on a factory standard engine. just for reference for people whom have had their heads or block's milled, or weather your using higher comp piston's.
