ye fuel is below quarter, and running a d series, fpr is standard
Its common after putting in the 255 the FPR gets funny , this may be the actual problem or not.
so better off buying both replacements???
upto you mate , you may have a lower fuel pressure due to the FPR, it may not be the pump you may have to get an adjustable FPR one w/gauge so you can monitor pressure. Before buying anything go to an actual workshop and get them to check it theres always so many variables with these things.
http://www.d-series.org/forums/force...-opinions.html
http://www.ht-archive.com/showthread.php?t=2691487
This may shine a little light for you too man , keep us posted in the result/resolution. Hope it gets soughted for you soon mate =)
mines abit hard to start when the fuel is under a quarter but anything above starts fine.
Interesting, so your gonna get same pump or oem ?
Smell for fuel leaks around the bay, maybe a loose fuel hose somewhere not giving it pressure.
Could be the dizzy aswell.
good luck let us know bro
Starter motor mate, I had that problem myself. If the fuel pump has been working fine for you for a while its unlikely to just **** up unless u changed the type of fuel or let the tank run dry
